Posted by Janicholson on October 23, 2008 at 13:50:45 from (66.173.50.11):
In Reply to: Attn: Jim N. posted by Dr. Bert on October 23, 2008 at 10:46:06:
It can replace the fluid and will probably be OK, but there are issues of operation that do not bode well for the swap. The Hydraulic fluid is (usually of less viscosity, and is often not EP rated, though some may be. 80-90 GL4 EP rated lube has a very stable thick viscosity that assists in slowing the gears when shifting. (especially from neutral into any gear). It also is formulated with extreme pressure additives which help keep the gears from actually touching under stress. The last reason is that the GL4 will be quieter in operation as it absorbs more sound. I hope this helps, Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
