Posted by Mr. Mayor on October 23, 2008 at 15:22:26 from (70.92.179.15):
I have a battery under the seat SH. It's been a long time since I took it apart. The pivot for the seat shows the rod, 352616R1, with two of the rubber bushings and 2 washers, 352650R1. Problem is it shows the washers inside of the bushings which makes no sense. The washers look quite small in the diagram also. Parts book is TC-49 rev. 2 11-59). The only wahsers that I have that I don't have a home for are are about 21/32" ID x 1 1/2" OD and quite thin. If I install them outside of the rubber bushings the ID is large enough for the rod to pass through so the washers would only be putting pressure on the rubber bushings. Make sense? Whats up here?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
