Re: Light switch wiring ???
Posted by ScottyHOMEy on October 23, 2008 at 19:06:03 from (71.241.206.164):
In Reply to: Re: Light switch wiring ??? posted by Bucky on October 23, 2008 at 18:17:16:
I'd go that route (changing the resistor) myself. Trick is I don't know what to recommend for a resistor. Can hope somebody that does will chime in.
You might also just check out the connections at the end of the old resistor and for continuity across it. It's not unusual for the fabric covering on that coil to look a little toasted and still be perfectly functional.
Check out BobM's very excellent wiring diagrams below. Good chance you'll find something in there to help you sort out the terminals and wires.
