Re: Is 55-60 psi dry/wet poor/good for a compression test ?
Posted by spiffy1 on October 23, 2008 at 20:31:01 from (70.41.136.71):
In Reply to: Tuesday Night F-20 Mystery: The case of the missing engine posted by poorfarmall1 on October 21, 2008 at 15:50:37:
If you're looking to take the head off anyway, and it's less than perfect why not; however, I'd say the money would most likely add up in the head.
Having a machine shop clean it up and magnaflux? Valves, maybe $20 each? Same for guides? Valve grinding....ect. It can add up quick.
On the other hand, I won't deny giving some compression to a Regular [where there were no sticky or obviously "loose" valves/guides to start with] by just pulling the head and grinding the valves, honing the polish off the bore (and abusing the hone instead of using a ridge reamer :oops: ), slapping on new rings, removing a few shims on the rods while replacing everything, and Wala. Not perfect, but it did reclaim some compression. :oops:
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
