Re: IH 656 Utility
Posted by hayfarmer on October 23, 2008 at 21:02:57 from (66.243.248.149):
In Reply to: IH 656 Utility posted by DaveIN on October 23, 2008 at 20:16:24:
with tractor off, work valve back and forth to relieve pressure then you should be able to remove fittings. Is it at the quick couplers? The on the back of the quick couplers it is tapered slightly, if that is where the leak is you can tighten them up. found this out by accident after removing one.
