Re: Int. 350 U Putting on new ring gear correctly
Posted by Owen Aaland on October 24, 2008 at 04:21:21 from (65.161.86.88):
In Reply to: Int. 350 U Putting on new ring gear correctly posted by Joyce Dunn on October 23, 2008 at 21:24:57:
If the teeth on the ring gear are chamfered, the chamfer goes toward the starter drive. If the teeth are just straight cut, look on the inside for a bevel. The bevel will go toward the flywheel. If the the teeth are straight cut and you have no bevel or two bevels, it can be installed either way.
