Posted by mkirsch on October 24, 2008 at 10:23:11 from (64.80.108.53):
In Reply to: IH 80 snowblower posted by 300winchester on October 24, 2008 at 09:03:01:
Why does it need to be so long?
Where'd you read that you needed a special PTO shaft? Maybe for a particular snowblower that used a shaft designed specifically for that blower, but not as a general rule.
You need a shaft that:
1. Is long enough.
2. Is rated for at least as much HP as the snowblower is designed to be used with.
3. Has the proper ends to fit the shaft on the blower and the shaft on the tractor.
4. Has a slip clutch, if your existing shaft has a slip clutch installed already.
Your best shot at getting the right combination of parts is to go to an equipment dealer that has an assortment of PTO shaft components that can be assembled into whatever shaft is desired. They may even be able to re-use your existing front and rear yokes, which will save you money especially if the rear yoke has a slip clutch built in.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
