Re: Re: Re: Fuel problem
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Chris on March 27, 2000 at 06:11:44 from (64.24.53.138):
In Reply to: Re: Re: Fuel problem posted by Jerry on March 27, 2000 at 05:30:02:
I tried blowing air up through the tank. The fix lasted for all of 50 feet. The only thing the worked was to completely clean the tank and seal it--if the problem is rust, that is.
What also helps is that the newer fuel bowl assembly protrudes about 5/8" above the bottom of the tank, whereas my original one was flush with the bottom. Helps to keep out trash and rust that didn't belong.
Post A Followup
: Re: Re: Re: Re: Fuel problem
