If you're talking about a tractor diesel injector pump its not hard. Look at the end of the shaft that drives the pump, you will see a dot near one end of the flat surface, there will be a matching dot inside the pump hole, turn the pump untill the dots will match as you slide the pump onto the shaft. Remove the two screws and the plate on the side of the pump, then slowly turn the engine in the correct rotation. If you have a pump with a stationary mark turn the engine untill the mark on the rotor lines up with it, then tighten the pump bolts. Depending on which tractor and pump you have timing marks will differ.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
