Karl, I thought about this for a while. Idealy I would have came off the divider, then to the loader, then to the remote manifold. It involved a lot more work and I would have had to make some new steel lines to make it fit properly.
The way I plumbed it was easiest as far as convienance goes. I have not put a load on the loader (pardon the pun) and tried to steer. I am sure I would loose some if not all steering while a loader spool is shifted. Most of the time one is not steering and using the loader. If it becomes an issue, I can install a secondary priority flow divider as you mentioned. I think they have them in Northern Tool.
I figured someone would find the flaw in the system. I knew that I was giving the system hydraulics a backseat to the loader but I had to do it this way to get above the 1600 psi relief in the remote manifold. This way I have 2000 psi at the loader, then feed the rest of the system with lower psi.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
