Re: 340U hydraulic pump conversion
Posted by RBX on October 24, 2008 at 19:34:42 from (70.241.26.71):
In Reply to: 340U hydraulic pump conversion posted by PaulW_NJ on October 23, 2008 at 19:47:59:
I did mine. Your serial # needs to have the
Z suffix (maybe) this would indicate that the
pickup tube from the rear area to the filter
cavity is in place. My pump, mounting plate,
& filter came off of a 504. The man at the
junkyard knew they are identical. I got the
new pump drive gear from IH, it's supposed to
enable getting the correct lash if I remember
right. I also used the valve set from the 504,
the bracket was easy to modify.
