Re: 966 hard steering
Posted by the tractor vet on October 26, 2008 at 08:40:09 from (76.212.239.237):
In Reply to: 966 hard steering posted by markinab on October 26, 2008 at 08:14:52:
Are you dure that there is no blowen gskt. or missing O/Rings ??? you did not loose the sump check plug and spring out of the lower right hand corner . Is the hyd. system at or above the full mark on the dipstick??? When was the last time ya replced the O/Ring on the hyd. filter coveror the gskt. under the the hyd filter plate .Did you check pressure on the MCV system ??? Did ya rebuld the MCv with a new seal and spring kit.????
