Hi Roger, in the resting position there should be 7" from top of foot rest to bottom of clutch pedal foot pad. This is adjusted by set screw by steering arm. The free movement is 1/2" and that is adjusted by loosening the two bolts on clutch pedal and rotating clutch shaft with wrench. We had 434(newer model of B414) back in the 1970s and we had the same problem getting the PTO into gear and adjusting the clutch didn't help. The problem was the pressure plate finger adjusting bolts had worn a groove into the finger and by turning the adjusting bolts 1/4 turn the bolts were no longer in the worn groove and it fixed the problem.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
