Re: 3pt hitch jumps up and down on International B-414
Posted by RogerMS on October 26, 2008 at 11:24:42 from (70.156.113.139):
In Reply to: Re: 3pt hitch jumps up and down on International B-414 posted by JimB2 on October 26, 2008 at 10:34:26:
I will try the depth control lever. I don't have the tractor here so I will have to try that a couple of weeks from now. Seems like I had pushed the depth control all the way forward and then nothing worked, but I don't really remember for sure.
What does the sensing rod do? How does it work? Do I adjust the sensing rod if pushing the depth control all the way forward doesn't work? If so, how do I go about adjusting it?
Thanks for the help.
