Pullng frame rails off an M
Posted by Etnfarmboy on October 26, 2008 at 13:41:24 from (75.139.10.18):
I am wanting to pull the frame rails off an M. I have the tractor blocked up and the front bolster off. Can I put a support under the front of the motor take one frame rail off and replace the bolts then remove the other rail? Any guidance would be greatly appreciated. Want to paint the motor is the reason for removing. Thanks again.
