Re: 400 power steering
Posted by Tim Shaw on October 26, 2008 at 15:41:31 from (66.241.182.192):
In Reply to: 400 power steering posted by Chris NW Ind on October 24, 2008 at 15:03:55:
53 diesel said: (quoted from post at 19:19:17 10/24/08) sooo it would be better to use seperate pump? what kind of pressure is okay, what is too much.
Since all you have is the steering motor, the easiest route to go would probably be a belt drivent pump. There was a pump mount that attached to the governor and used a Ford PS pump. I think that may have been the Charlynn set up. Sorry I can't be more help. I added to factory set up to my 350 and that's all I've ever messed with.
