Re: SMTA Won't Sart
Posted by El Toro on October 26, 2008 at 17:19:32 from (205.188.116.73):
In Reply to: SMTA Won't Sart posted by retcol on October 26, 2008 at 15:40:39:
When you get No1 piston to TDC on the compression stroke Look to see where the rotor is pointing. It should be at the No1 plug tower. Hal
