F-20 Serial #
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Corey on March 27, 2000 at 10:46:46 from (150.108.90.45):
I am looking for the serial number on an F-20. I found a number stamped into the block on the flange that bolts to the transmission. It reads 1565DA. I was not able to cross reference that anywhere. Is this the serial number or is it elsewhere? Thanks for your help.
Post A Followup
: Re: F-20 Serial #
