Re: Mis-marked generator??
Posted by Janicholson on October 27, 2008 at 19:45:47 from (66.188.163.79):
In Reply to: Re: Mis-marked generator?? posted by Dr. Bert on October 27, 2008 at 19:14:05:
There needs to be a method to adjust gen output. If it has no light switch, the F terminal must go some where. It needs a ground to make full output, Or it could be a "B" circuit generator. if it is, it will be getting battery voltage at the F terminal to make it go. Trace the wire from the Little terminal to see where it ends up. sense it is charging it can't be all bad! JimN
