Re: Rear wheel weights on 1066
Posted by the tractor vet on October 28, 2008 at 06:21:16 from (76.212.239.237):
In Reply to: Rear wheel weights on 1066 posted by mjs on October 28, 2008 at 04:51:32:
Well myself I might dump the wheel weights but i would never remove the cal. we have one 1066 with loaded tires and that tractor belongs to my one buddy and she has loaded tires that are Firestone Field and Road with tread that is around 60-65% , neighbor has a 1066 with one year old Firestone's that are the Altrac's Field and road in 18.4 X38 that tire is a lot better tire then we have on Eugene's BUT no fluid. They pull a 13 and a half foot disk and spin up the hills with it they can not even pull a 3/4 loaded silage wagon up the one hill on the tar and gravel road as they spin out . Now they have added five sets of donuts and they still are spinning in the field with the disk . Ya have to remember that a 1066 has some giddy up and go power and if it like most 1066's that i have been around SHE AIN"T STOCK setting on the pump and you will burn more fuel by slipage then you will with fluid in the tires . Yes i know all of the down sides of fluid in the tires BUT , if you FIX that thorn hole or small leak when ya first notice it and ya keep the tire valve from leaking then you won't have rusted out rims.Plus the fluid makes that tractor more stable . One can never stack enough iron on to equal the fluid. and you will not get the same traction with the iron.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
