Re: M ignition
Posted by Janicholson on October 28, 2008 at 09:12:57 from (199.17.6.128):
In Reply to: M ignition posted by Terry Smith on October 28, 2008 at 08:55:38:
It can be any of the above.
The unit was sold as Positive ground 6v with generator and either a voltage regulator if 49 or newer (not sure on exact break date) or a 4 position light switch that manually regulated the charge rate, and a cutout relay.
If it has an alternator, it is probably 12 volts, and it can have a voltage regulator seperate from the unit. Many early alternators were made like that including all the major auto manufacturers. If it is not working, Use the following link to get it right. JimN
