Re: Starting a McCormick-Deering 10-20
Posted by spiffy1 on October 28, 2008 at 09:49:41 from (70.41.137.72):
In Reply to: Starting a McCormick-Deering 10-20 posted by Andy Motteberg on October 16, 2008 at 18:33:10:
Yep, if the button is down, the pawl [just a little 'finger' that engages a ratchet; not exposed on a F4 mag like an E4] will engage at the beginning of the stroke, and the mag [from the output end that is, the end you turn still does; if on a bench you'll be able to turn it with some leverage and feel the spring resistance building up] won't turn until the top of the stroke [every half crank], when it releases with a very audible click: giving the mag a quick spin for [now a real mag expert will give better reasoning :oops: ] the coil as well a clean break at the points.
The button should not push itself up, and if the tractor doesn't start the pawl should reingage [without pushing the button again].
Of course, if you still have no compression [I never even thought about the obvious here: how does does the crank feel with plugs in vs. plugs out?], even a hot, well timed, spark won't ignite anything [probably not drawing intake either then].
This post was edited by spiffy1 at 09:52:38 10/28/08.
