Re: H brake cover
Posted by glennster on October 28, 2008 at 10:06:06 from (76.222.61.197):
In Reply to: H brake cover posted by teddy52food on October 28, 2008 at 10:00:43:
shaft should stay on the tractor. prolly full of rust in there. loosen the bottom jam nut and back the bolt out some. that bolt holds the bottom of the brake band up.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
