Have you checked the points to see if they're still opening and closing? Rub those points with some 320 wet or dry until they're shiny. It they're pitted, replace them. Check at the coil with the points open for battery voltage. You need the ignition switch on too. Use a test light or volt meter. If there's no voltage at the coil, check the ignition switch for voltage. Could be a broken wire if there's none at the switch. It may may be fed off the starter solenoid if it has a solenoid. That's the small terminal that's close to the battery cable on the solenoid. Hal PS: Very windy here in MD today.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
