Re: Need ELECTRICAL Help ASAP.
Posted by a4t1rat on October 28, 2008 at 13:37:48 from (209.253.36.97):
In Reply to: Need ELECTRICAL Help ASAP. posted by Butch WI on October 28, 2008 at 13:01:46:
You should have one wire on the coil that goes to thr dist. and one that goes to the ing switch / battery. the points are in the dist. the part that rotars around is called the rotor. if you have a test light see if you have voltage on the battery side of the coil. if not its probaly the switch. you can run a jumper wire from the battery to that terminal and that should give you spark. if you have voltage there then I would say its going to be one of the following the coil, points or the condensor.
