Re: Dist interchange
Posted by Jim Becker on October 28, 2008 at 13:57:00 from (96.226.61.120):
In Reply to: Dist interchange posted by Farmall A on October 28, 2008 at 09:16:16:
Yeah, what Owen said. The rate and speed at which the advance comes in is determined by the springs. Unless someone has been swapping internal parts around, you can tell which version you have by the code letter stamped into the distributor mounting flange (not the battery ignition unit flange).
The early distributor for the A was code A, the same as the M used. Later A distributor was code J.
