Posted by El Toro on October 28, 2008 at 14:05:36 from (205.188.116.73):
In Reply to: battery drains dead posted by Knbshn on October 28, 2008 at 13:35:21:
That's probably a master switch that someone has installed and it should prevent the battery from draining. The military has used these for years. Measure the battery electrolyte with a hydrometer to what reading you get. A fully charged battery should read around 1.260 or better. I would put the battery on a charger overnight then check each battery cell and compare the readings. They should be close to one another. If one read's 1.100 and the rest read 1.260 or better then discard the battery and check your charging voltage at the battery with a volt meter when you get a new battery. Should read 7.25 volts on a 6 volt battery and 14.0 volts ona 12 volt battery with the engine at 1/2 throttle or better. Hal PS: If the battery readings are ok on the old battery you still need to check the charging voltage.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
