Re: Need ELECTRICAL Help ASAP.
Posted by El Toro on October 28, 2008 at 16:35:01 from (205.188.116.73):
In Reply to: Re: Need ELECTRICAL Help ASAP. posted by Butch WI on October 28, 2008 at 16:02:07:
That sounds like a ballast resistor. I would install Napa's coil IC14SB cost about $18.00. It has a built in resistor so remove the inline resistor if you use their coil. I would try another condenser before buying a new coil. It could be causing the no start. Hal
