There are two kinds of coils on 12 volt systems One, the kind you are wired up for, is a 6 volt coil that requires an inline resistor (the ceramic piece you see) to reduce the voltage into the coil.
The other takes a 12 volt input but has the resistor built into the body of the coil to reduce the voltage, eliminating the need for the inline resistor.
If for some reason your inline resistor went bad, that could have fried your existing coil.
So, two thoughts. If you go with a 6 volt coil, I'd replace the resistor (they're readily available) as part of the project. The alternative is to go with the 12 volt coil with the built-in resistor, in which case you want to take the resitor( the ceramic piece) out of the line in.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
