SHORT ANSWER YES that means you OUGHT to have a 6 volt coil NOT A 12 but I cant say sittin here what you actually have?????????
1) If theres a fuse between the IGN switches IGN output and the Ballast Resistor (that white ceramic/porcelain 2 terminal box between ign and coil) it obviously has to be good n working and continuous (not blown)..... the current draw is around 4 amps so a 10 to 15 amp fuze (depends on wire size used) would be fine
2) If its a 12 volt tractor and uses that in line series voltage dropping (12 to 6) ballast then YOU NEED A 6 VOLT COIL NOT A 12. Or else discard the ballast and use a full true 12 volt (some lay persons call internally ballasted) coil n be done with it. Its input wires to the switch and output to the distributor. NO BALLAST NEEDED
3) If the coil is bad as you claim, Id buy a new full true 12 volt coil and toss the old ballast.
4) Coil testing: This was already posted in my Troubleshooting Procedure...... If you use an ohmmeter the coils primary resistance as measured between its lil + and - terminals should be around 1.5 ohms for a 6 volt or 3 ohms for a 12 volt.... IF ITS AN OPEN CIRCUIT (near infinity ohms) ITS BADDDDDDDD The HV secondary should be like 5k to 10 k ohms and if its open its badddddddd. HOWEVER even if it passes both tests it can still be bad cuz it breaks down at High Voltage and/or temperature. Thsi test only shows if its definitely baddddddddddd not if its totally good.....
5) If you ran my troubleshooting procedure below it shows how to tell if non firing is a coil etc or a distributor cap n rotor problem so I will take you at your word the coil is bad. Remember as posted below a volt meter or test lamp on the coils output (to distributor) terminal usually reads zero cuz if the points are good n working n closed that point gets effectively grounded out.
Since you determined the coil is bad you just as well get a new 12 volt n go for it although its more often a points or condensor or cap or rotor problem etc before its the coil
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
