Re: Farmall C Carter float level? WOW the H is finally h...
Posted by Ron-MO on October 29, 2008 at 09:39:07 from (63.87.140.3):
In Reply to: Farmall C Carter float level? WOW the H is finally home! posted by Calif. Farmall on October 28, 2008 at 21:53:03:
I have a spec sheet for the Carter (from Carter Carburetor), and it says.....
Top of float 11/64 inch plus or minus 1/64 below top surface of upper body casting
This is the same carb I have on my C.
Hope this helps.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
