hey anyone with a 450 that doesnt steer good
Posted by 756puller on October 29, 2008 at 17:42:39 from (98.135.7.216):
i have found a solution, take and mount a secondary valve on the side of the tractor, cut into the pressure side of the pump and run a line directly into the behlens unit, leave the hose unhooked from the tractor valve, run the other port bact to the other end of the tube u cut so excess oil can go to sump
