Re: hydro lines rotted on a farmall 400
Posted by charles todd on October 30, 2008 at 04:22:13 from (205.242.95.138):
In Reply to: hydro lines rotted on a farmall 400 posted by TimChandler / S-OK on October 29, 2008 at 22:04:02:
If it is not too bad of a leak, brazing is ok for pinholes. But pinholes mean that it is thin. Was the corrosion from the inside (moisture) or outside (battery leak). Be careful brazing. I was TIG welding a hole in a small tube one time and let the puddle get a little too hot. SPLAT I filled the line up with silicon bronze filler. I would pay a little more and have a new one built, you have a good pattern, for now.
Charles
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
