Steering mechanism is identical for both Stage I and Stage II Super H - and also the regular H for that matter....
If the pivot shaft (the shaft coming out of the bottom of the steering box) is turning with the steering wheel the ONLY way the front wheels cannot turn is if the pivot shaft has snapped near the bottom.
The pivot shaft is a single piece forging. The worm wheel is mounted on a tapered spline at the top end, and the lower bolster/front wheel assembly is bolted to the square flange at the bottom. There's no key, etc that can shear.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
