Re: Stage II Super H steering problem
Posted by mkirsch on October 30, 2008 at 08:02:32 from (64.80.108.52):
In Reply to: Stage II Super H steering problem posted by Farmboy856 on October 30, 2008 at 04:17:32:
Hmm, if the shaft that comes out of the bottom of the steering gearbox is turning properly, that's not good.
I believe that shaft from the splined end that holds the gear all the way down to the plate that holds the pedestal is one solid piece of steel. The plate is welded on the bottom.
This means the shaft itself has broken off somewhere in the lower part of the bolster. There must be enough of a stub left on the pedestal plate up into the lower bushing to keep it from falling off.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
