Posted by RustyFarmall on October 30, 2008 at 08:40:10 from (209.152.78.71):
In Reply to: Re: smoking H posted by RustyR on October 30, 2008 at 07:44:56:
Valve seals are not original equipment. That hairpin clip is to keep the valve from dropping into the cylinder in the event that the spring breaks. You CAN install valve seals or umbrellas if desired. Quite a few Hs smoke blue for 15 seconds or so after start up. It isn't right, and really should not be happening on a freshly rebuilt motor, but it doesn't really hurt anything. You can either tear it down and install the seals or you can just live with it. If it were mine, I think I might go have a talk with the machine shop that did the work.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
