Re: Question For Tractor Vet
Posted by Red Mist on October 30, 2008 at 15:40:49 from (67.142.130.29):
In Reply to: Question For Tractor Vet posted by Eric Bergstrom on October 30, 2008 at 15:25:57:
Eric Bergstrom said: (quoted from post at 15:25:57 10/30/08) Sounds like you two are pretty knowledgeable when it comes to clutches. The clutch in my H seems to engage almost immediately when you begin to let off the pedal. Is this something I can adjust or am I going to have to start replacing things in there?
I've had it apart for other reasons before, but don't know much about my options in this case.
Eric: I am not an H expert on clutches, but the rod from the pedal to the fulcrum is adjustable. Did you check it? Also, there should be 1 + 1/8 inches of free play before you start feeling pressure as you depress the clutch. Measure off the front of the deck. This is a critical measurement. Hope this helps. mike
