Re: Farmall M bolster
Posted by James Rumph on October 31, 2008 at 11:47:19 from (24.192.125.175):
In Reply to: Re: Farmall M bolster posted by Dougie94 on October 31, 2008 at 11:15:14:
This is a very talked about subject. This is a very common problem with these tractors.
There is a shim that people put in these , they pump the bolster full of greese etc etc..
It all boils down to worn parts, top gear -worm gear, universal joint in steering shaft.
There isn"t a easy cheap way to cure this.
I would just do a search on the topic and see which fix best fits your tractor.
Just make sure the bearings are set correct and that the tires are good and the rims not bent and live with it.
Sure wish i had the end all answer !!
