I disagree with JT. A 1/2 ton truck with the proper set up can safely pull a loaded "deckover". I have a 1979 3/4 ton 2wd and a 2001 1/2 ton 4wd truck. I have a home built gooseneck hitch in the 1979 and a B&W in the 2001. I pull my 504 with a Koyker loader, loaded tires, cast wheel weights and (an implement if needed) behind my 1/2 ton. I pull 60 miles one way feeling safe all the way.
I just recently installed 4 new tires and wheels as well as replaced all 4 brakes on this trailer. I had some split rims on it prior. I plan to extend this trailer to 25' plus a dovetail for a total of 30'. Also I am going to add a 3rd axle. In a couple weeks I will post a picture of my load when I go pick up my tractor from the farm.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
