Re: 424 ignition problem
Posted by Bob on November 01, 2008 at 00:43:10 from (69.178.228.68):
In Reply to: 424 ignition problem posted by Tedly on October 31, 2008 at 22:50:42:
The wire from the starter to the coil bypasses the ballast resistor during cranking (with the starter).
If you have a bad wire from the ignition switch to the ballast resistor or a bad (open) ballast resistor, the tractor will act just as you describe.
I can't remember the exact circuit, but don't think it will crank (with the starter) if the actual ignition switch has failed.
I don't know the exact value of the ballast resistor, but expect a reading in the 1.5 to 2.5 Ohms range.
