Re: Loosener Preference
Posted by Charles H. on November 01, 2008 at 15:07:23 from (12.72.29.202):
In Reply to: Re: Loosener Preference posted by russ/ks on October 31, 2008 at 14:16:14:
I spray stuff with soapy water and keep them wet if I have time to let things soak.
Sometimes I heat then soak with soapy water, or what is known as wetter water, LOC from amway was a product which did it. Every leave a tractor in the elements and have to drain everything?
As far as putting something in an engine I use marvel/transmission and penetrating oil, sometimes a diesel.
