super c starter motor
Posted by lachleaves on November 02, 2008 at 09:03:32 from (81.141.1.209):
In Reply to: Re: super c dynamo - bearing's gone! posted by ScottyHOMEy on November 01, 2008 at 17:32:38:
thanks for the advice, but before i pick your brains further about the starter motor switch and linkage, i need to clear up a couple of things about the battery...
my 6v battery is absolutely duff! so, until i get a replacement, if i just want to test the starter i can connect a 12v battery, yes? i'm right in assuming the tractor is positive earth, aren't i? so if i connect the 12v battery - and connect the positive terminal to the earth lead of the tractor - why would that require me to repolarise the generator when i find a 6v replacement battery in the future??
and, as long as i don't pull the ignition switch on, the 12v battery won't damage the the points or ignition system, no?
sorry, perhaps silly questions, but i just want to be sure...
thanks
