Re: Thirsty M
Posted by El Toro on November 02, 2008 at 15:08:06 from (64.12.116.73):
In Reply to: Thirsty M posted by zeke250 on November 01, 2008 at 14:10:51:
You may have blockage in the fuel line from rust and dirt. Could be in the tank too. Pull the gas line off at the carburetor and see if there's a full stream of gas flowing out. There's a screen behind that gas tube fitting your gas line was connected to and it may be plugged. Open that main jet at the bottom of the carburetor too. Hal
