Re: F-12 Fan belt
Posted by Dave Allgire on November 02, 2008 at 15:58:48 from (24.217.35.194):
In Reply to: F-12 Fan belt posted by randmih on November 02, 2008 at 09:32:47:
If you will look at the underside of the shaft of the fan you will find a long threaded bolt with a locknut on it. Loosen the locknut; back the threaded bolt out. It takes a 1/4" wrench. It will have to be backed out a long way. Next loosen the nut on the fan shaft in front of the bracket. That will take a 7/8" or 13/16" wrench. It has to be narrow to fit between the bracket and the belt pulley of the fan blade. Fawteen is right in that the support that houses the crank extension needs to be moved forward. There are two bolts holding this bracket to the side rails. Remove the bolts, slide the bracket forward and this should provide enough clearance to install the new belt. After installation of the new belt, reverse the above process. CAUTION: Don't overtighten the belt. There should be between 1/2" and 5/8" of deflection after the belt is tightened. Hope this helps.
