Re: A Continuein' Saga of a Farmall A Magneto
Posted by Jim Becker on November 02, 2008 at 20:08:15 from (96.226.61.120):
In Reply to: A Continuein' Saga of a Farmall A Magneto posted by Trav W on November 02, 2008 at 17:35:04:
Wild Bill Caldwell said: (quoted from post at 18:35:04 11/02/08) I drove back down, copied the castin' numbers off the block...I'm wonderin' if They replaced the A engine with a 240 engine. Here is the number behind the oil filter...6342*OH.....same side down close to oil pan at the front...5*22*0, last number the asterisk represent the screw heads in the numbers.
6342*OH is probably 6342DH, which is an original block number for an A. That makes 5*22*O May 22, 1945.
