IH 674 Power Steering Problem
Posted by Floridaboy on November 03, 2008 at 05:14:58 from (209.149.201.5):
third party image
Well, finally got my fuel problem fixed and now have I have a power steering issue. The pump/valve unit underneath the steering wheel has been leaking (not too bad) for a while. This weekend it started pouring fluid. I moved last year and can"t find my manual. I"m assuming it has seals that are shot. The bottom bolts are tight, but the outside shell will spin. With the engine off, you can turn the steering and get fluid out of the unit.
Is it better to try to rebuild? Buy a new unit? Buy a rebuilt unit? Where is the best source?
Thanks in advance.
