Re: IH model 39 plow
Posted by Jim Becker on November 03, 2008 at 06:15:09 from (96.226.61.120):
In Reply to: IH model 39 plow posted by Danto on November 02, 2008 at 16:47:49:
Hugh,
It's been a while since I watched one work, but as I recall Wayne is correct that the rotation of the tires does not power the lift. I believe it is the rotatoin of the subframe that does the lifting.
Pulling the rope releases the subframe, allowing the ground force against the plow bottoms to cause it to rotate 1/2 turn. The rotation raises the plow while bringing the opposite set of bottoms into place for the next pass down the field.
