Posted by RustyFarmall on November 03, 2008 at 09:34:33 from (209.152.78.71):
In Reply to: 300 Starting Question posted by EUG1206 on November 03, 2008 at 08:30:55:
If that engine is getting weak and the compression is low because of worn rings or leaking valves, pulling it will usually get it to start quicker because the engine turns over faster than if you used the starter. The faster that engine turns over, the greater the chance of building up enough compression to get it to start. Another thing, which might be less expensive to fix, is to make sure the battery is fully charged. A weak battery COULD have enough power to turn the engine over, but not enough power to energize the coil and ignition system. Poor electrical connections can also cause the same thing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
