It hasn't run in 20 years, the exhaust is NOT covered which means the engine is STUCK. You'd have to spend the better part of a day cutting all of the iron off of it before you could even think about loading it, it is located about 300 to 1,000 miles from anywhere, and then it probably is nothing more than a pile of scrap iron. I don't like to see these old tractors go to China anymore than anyone else, but you can't save all of them.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
