Re: Gas vs. Diesel revisited
Posted by dan67 on November 03, 2008 at 18:37:01 from (66.233.206.219):
In Reply to: Gas vs. Diesel revisited posted by Jason from MI on November 03, 2008 at 14:49:05:
We get to sub zero quite often and we run Diesels, as long as you have winterized fuel and a a block heater no problem.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
